Removing a tea/coffee stain from a leather sofa?
17 Oct 2002
In my penthouse, Park Ave
Unfortunately one of my sofas seems to have aquired a tea or coffee stain down the side of it. It's a light sand coloured leather and nothing I've tried seems to help shift the run marks. Anyone got any bright ideas?
Keep licking it until it comes off:D
Have you tryed lemon? that cleans most things.
Or some stain cleaner?
6thElement said:
I've tried most of the kitchen/bathroom cleaner "stuff" and they're having no effect :/
I wouldn't try them too much as the chemicals they contain may stain your sofa worse than the tea/coffee does!
Strange one:
Traditional wisdom recommends treating ink stains with milk or tomato. Cover the stain with a little milk or rub it with the cut side of a half a tomato. Take more care with the tomato remedy, as tomatoes contain some acidity. Rinse either treatment well.
If it works for ink I can't see why it wouldn't for other stains. I'd be careful though, they're both quite acidic. There's scope for making it worse and don't come to me :p
We have some wet wipes that claim to be especially for leather which seem to do the job on red wine. Am pretty sure that they were bought from wilkinsons.
Mix a solution of 1 quart water, 1 tbsp. white vinegar and 1/2 tsp. detergent (such as dishwashing soap).
apply with a sponge, and allow to soak for 10 minutes or so... Then wash off.
Vinegar can be mixed with linseed oils as well... Conditions the leather at the same time.
use mayonaise....trust me it works (also works on wood where you get coffee rings.
It supplies natural oils back to wook and leather and removes staining in the process.
Which is just lemon or vinegar and oil in eggs. Basically the same as what I suggested, just that the eggs in the mayonnaise creates a cream to smear it on the stain with. Linseed oil is better to condition leather with though. It helps to stop the leather drying out, and can help to prevent cracking overtime. I clean my leather suite with water and soap, and drop a little linseed oil in. On bad soils, I just use vinegar.
You'd be surprised what we eat you can actually clean with.... :p
Like a few other posters have mentioned I have heard that vinegar is good for removing tea/coffee stains.
