Hi. A friend has had the cooling system on his PC die, and I'm going to give him a hand replacing it. It turns out it's a Watercooled system cooling the CPU only.
I've got a replacement air-cooler (the system isn't OC'd so it should be ok) but while I've built many PC's in the past, I don't have much experience with Watercooling.
I've not seen the system yet, but it sounds like there's a cooling fan on Watercooling system that isn't turning. Either it's failed or (more likely I think) the whole pump is dead.
How do I safely remove it?
Thanks for any help,
