Hi,
I'm going to be making a new logo for the front of my eclipse and need to remove the painted on akasa logo first. Has anyone done this with success and if so what did you use?.
This is a logo i made from aluminum as a test, the one for my case front will be better than this (and will say akasa
I was thinking of getting some nitromores (sp?) but i have a bad feeling that it will melt the plastic front
. The new logo will be made of brushed stainless steel and might be the same size so i can use anything that will leave a mark i.e wet and dry.
The only other thing i could do is make the letters exactly the same size or slightly bigger and stick over the top of the paint. I was toying with the idea of doing a handwriting style logo though so that would ruin that plan.
Ive also got some silver HIFI style feet to put on tomorrow, I'll post some pictures up once Ive done it.
TIA
).I was thinking of getting some nitromores (sp?) but i have a bad feeling that it will melt the plastic front
. The new logo will be made of brushed stainless steel and might be the same size so i can use anything that will leave a mark i.e wet and dry. The only other thing i could do is make the letters exactly the same size or slightly bigger and stick over the top of the paint. I was toying with the idea of doing a handwriting style logo though so that would ruin that plan.
TIA
