Removing all Java versions / files, help
Don
21 Oct 2002
Parts Unknown
Anyone got a shotgun blast fix for getting rid of Java installs?
Multiple machines with different states of Java, some up to date, some not. Versions 6 and 7. Some only 'half' installed, so the normal installers fail.
Thanks..
Doesn't work.
Still has Control Panel entry, Add/Remove entry and C:\Program Files\Java. This folder has 6 and 7 in it, along with some files in each.
Try Your Uninstaller to remove everything and set it to use the most aggressive mode, then run CCleaner just in case.
Stoner81.
