- 26 Dec 2009
- North
Hey,
I need to do some modding to the internal panels of my Lian Li X2000 case for an upcoming build. Easiest way is to remove rivets, remove from case and then cut.
1) Drilling rivets to remove
2) reinsert with something like this? http://cgi.ebay.co.uk/POP-RIVET-GUN...t=UK_Hand_Tools_Equipment&hash=item483fefb6e3
Will that rivet gun do? Also what size rivets will i need or how can i measure the current ones to know what size i need. Im assuming you measure the head?
Also i think the rivets in the case are countersunk? as they level with the case. Will i need to buy countersunk rivets? if theres such a thing!
