Trying to remove the the waste on my bath as it needs replacing, however the screw which holds it down is continuously spinning. It is also a very wide screw which has two slots on either side instead of one continuous slot. I think would need a screwdriver with a head about 20mm wide to easily rotate it. Have been using a steel rule which does work but is a bit awkward. Can't seem to find anything else I have which would be more suitable to unscrew it. Anyway the main issue is that despite turning it several times, it doesn't seem to be getting any looser. Any ideas how I can go about getting this off? See pictures below.
