removing broken dart shafts
18 Oct 2002
I have 2 darts with the threads broken off below the metal sections. Its very hard plastic and have tried scratching a line into it to, to see if we could unscrew it to no avail. Ive tried melting it out, no luck.
Any quick answers as i want to use them now:D
use a dremel to drill a small hole through the plastic, get some small screws with an opposite thread, screw em in utill the plastic starts to unwind.
just and idea, but could potentially work.
heat a thick pin up with a lighter/gas flame while holding it in something heat resistant (pliers ideally). Stab it into the shaft which will melt and then wait for it to cool and set around the pin then twist and unscrew the old shaft
perhaps try as above with a small knife/screwdriver, heat chosen implement and carefully force tip into the plastic, with a flat section it should be better for unscrewing with better purchase than a pin? I have little knowledge of dards but this seemed logical to me. Knife is potentially more dangerous but its sharp tip will obviously cut better than a screwdriver.
