Removing Dealer Window Stickers
  • Thread starter Thread starter Guest
  • Start date Start date
Use a hair dryer on low heat & waft in over the sticker, Once warm it will peal of easy & leave no mess. Don't go mental with the hair dryer though, Slowly softly. ;)
If it hasn't been on long just try peeling it off. The one on our Punto came off one pull about a week after it was stuck on.
Oh... just saw the last post :o
Rip them off if it leaves any stickyness get sticky label remover, it's ridiculous how many stickers the dealer put on my car.
Did you try the search button? I only say this because its been covered soooo many times:D
This has always worked for me;
Gentle heat with a hair dryer, peel off slowly and steadily from a corner trying to keep it all in one piece.
To finish, I have a can of spray solvent degreaser stuff that lifts the residue off lickerdy split.
A quick rub with some household glass cleaner = job done:)
I didn't get that far down, just replied to the opening post :)
*reads*
My bad, seems you sorted it!
I had to take a very old sticker off the front windscreen yesterday - some sort of old tag for M6 toll road I think it was. It wasn't going anywhere until some gentle heat!
