removing dual boot help
1 Feb 2006
hi,
i have xp installed on one drive and a beta version of vista on another partitioned drive. How do I remove vista and just have xp as my default operating system again? Without using the "select os" message on bootup?
Any help would be much appreciated
type c:\boot.ini in the address bar on the my computer window
then it will open in notepad there you can edit the line to remove the unwanted part of the boot
make sure you only delete the right line or you cant get into windows
if you do it wrong then you will have to fix it using the windows xp console.
this is what my file looks like
Code:
;Warning: Boot.ini is used on Windows XP and earlier operating systems.
;Warning: Use BCDEDIT.exe to modify Windows Vista boot options.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /FASTDETECT /NOEXECUTE=OPTOUT
I think there must be a different way to remove vista installations judging from what that says
mm jonnyc747 from that code you posted thats only showing me 1 OS boot listed.
so the boot.ini must be on the other partition
that software modo77 posted might do the job. but i cant say for sure
as ive never used it befor
thanks for the links guys... that easybcd tool is very handy.
I have now removed vista from the boot listings. Does that mean that it is now safe to format my vista partition? I have a feeling though that my boot files are now stored on the vista partition automatically when vista is installed and the dual boot options set up.
I notice an option in easybcd sayin "uninstall the vista bootloader (use to restore XP). It is under the "manage bootloader" menu.
Is this what I would be looking to do before removing vista?
Vista doesn't use the boot.ini that's why.
yes
Do you mean yes as in its safe to delete vista partition now?
Or do you mean I have to select the
"uninstall the vista bootloader (use to restore XP)."
option in easybcd and then delete partition?
Thanks
Yes. :) Use the uninstall vista bootloader. That'll put it all back to pre your vista install. You can do what you want with the 2nd hd
