21 Apr 2006 at 15:42 #1 Craig321 Craig321 Soldato Joined 2 May 2004 Posts 19,950 Hi, Is there any way I can remove the HP sound in RF please? I tried replacing it with a blank sound file yesterday but it just checks it and replaces it with the auto patcher. Any ideas how to remove it / disable auto patch? Thanks, Craig,
23 Apr 2006 at 21:57 #3 Sweetloaf Sweetloaf Soldato Joined 5 Mar 2004 Posts 6,399 Location Southport No idea what file you are on about but try renaming it!
23 Apr 2006 at 21:58 #4 benjo plz. benjo plz. Soldato Joined 15 Jan 2004 Posts 14,199 Location Hall replace it with a blank file, then change the files security so that your user can't write it, just read it.
23 Apr 2006 at 22:40 #5 Craig321 Craig321 Soldato OP Joined 2 May 2004 Posts 19,950 Ill give that a try Phnom. Ill post back here when im done Sweetloaf said: No idea what file you are on about but try renaming it! Click to expand... The annoying HP Potion sound in RF Online. --Edit-- Tried changing the permissions and replacing with a blank file with same name but the auto patch when you start the game still replaces it Craig. Last edited: 23 Apr 2006
