Removing Kaspersky addon from Outlook
3 Nov 2003
Lancashire
as it says really, used a email backup program to backup all my outlook settings before wiping my system and installing Vista RC2
everything works fine, its just that I had Kaspersky on my XP build and because it doesnt work on vista I have had to use AVAST.
anyway, i restored my email settigs and its obviously copied across the Kaspersky settings to, and when I boot outlook 2007 beta 2 it says
'the Add-in "Kaspersky Mail Checker" can not be loaded and has been disabled by Outlook, please contact the addon manufacturer for an update, if no update is available please uninstall the add-in'
Any ideas, i cant find an add-in section in outlook, and becuase iv never installed it on vista I cant uninstall it there ?
the nag screen every time I boot outlook is doing my head in
