Removing LED from Zalman 9500 cooler?
3 May 2006
Has anyone removed or changed the blue LED inside the fan of Zalman 9500? I want to remove the LED or at least stop it working. Has anyone done that before? I want to go for a green UV theme so the blue LED won't help with the effect. If it is possible to swap it I might try putting a UV LED instead with some UV paint on the inside.
I've seen the whole fan changed to a quiter Nexus one but I want to stay with the stock one if it is possible.
