Removing Lian-Li PCa10B Front Cover
13 Sep 2007
As the title suggest wondered how difficult it was to remove the front cover, as i need to get behind it to fit lian-li cd drive covers. Some pictures would be gret if possible.
Thanks
Doesn't this have a door to cover up the drives anyway?
From pictures on reviews it looks like you can, as there are the screw holes to mount the bezels. It looks like youI'd have to unscrew the front at the top and bottom of the front where the plates with the hinges are.
If it was me I'd just start carefully unscrewing stuff. As long as you remember what goes where and don't lose any bits you can't do any damage to it.
PK!
dont think you can remove it from memory. you'll need to remove all the drive bay covers, then jimmy them in. I managed to get two in, but it takes some effort.
