Removing\masking scratches
Caporegime
18 Oct 2002
Ireland
Just got my first scratch tonight thanks to some dodgy pressure washer work. Tried some tcut on it and its stil pretty obvious looking, cars a pearlescent black. Any other types of scratch remover that come reccomended?
Your own doing or some dodgy handwash comprising a team of foreign gentlemen out of interest? :)
All T-cut does is takes the paint off. It's a harsh but effective cutter.
I'd say the scratch is too deep.
Then you aren't putting enough effort in. A scratch that you can't even feel with your finger nail will polish out, forget T-cut.
damn your paint must be soft or your pressure washer insane if it managed to scratch the paint from a quick burst!
Thats what I was thinking? How on earth can a pressure washer actually scratch something? Strip the paint maybe, but scratch?
If its deep enough to fit your finger nail in even barly it will never polish out.
Can you get your hands on a machine polisher, or take it to a detialer and see what they say.
Check detailing world for a list of detailers near you, would prob be your best bet.
I had a nasty scratch on my 728i BMW, a few coats of Colourmagic* and it went away. :)
* A kind of T-Cut / Polish mix thats coloured to match your car, obviously, for a Black car, I got the Black one.
It works by filling the scratch with the coloured polish & works well imo...... - I have a mate who tried to use the same product on his Blue A4, trouble was, the colourmagic was Green, yes, he ended up with lots of highlighted Green scratches!
http://www.cleanyourcar.co.uk/polishing/polish/menzerna-250ml/intensive-polish-po91l-/prod_216.html
This is probably the best hand polish available, it's the best you're goin to get without machining. It probably won't completely remove it but will round the eges of the scratch so it makes it far less visible. Follow it up with something full of fillers, such as auto glym SRP or a glaze such as poorboys black hole and it should be barely visible
This man speaks the truth, good advice for anyone really who has not got a PC handy. follow up with lots of thin layers not one big thick layer. Several layers are much better than one single thick layer.
