- 23 Dec 2013
- North Wales
Around the CPU socket of my motherboard there seems to be a bit of a buildup of moisture which i suspect was down to a bad seal on my Triton AIO which is being RMA'd. Thankfully the coolant i used in it was non-conductive so is relatively harmless. Only it won't dry with heat applied for some reason.
What would be the best way of removing the moisture? Despite it being harmless i would like to remove it. After some googling some are suggesting to use spray on Isopropyl Alcohol or some form of non-conductive solvent, which will be able to evaporate the moisture. Any suggestions for removing moisture off my mobo without damaging it?
