Removing mould from a picture frame
16 Mar 2005
UK
Hi,
After moving house recently we found that we had a bit of a damp problem in the previous property. We've found some patches of mold on the back of a large picture we have.
What's the best way of getting rid of this? I've wiped it over with a damp cloth but it just comes back. The back of frame where the mold is is hardboard.
Thanks
Oddly, I hadn't even considered that. I've heard of people mentioning bleach but I'm not sure I want to put this on there!
Buy a new frame?
Watered down bleach would prob be alright, test on a small area first. Failing that white vinegar.
u won't get rid of it from hardboard unless u dry it out in direct sunlight or a oven it needs replacing really. walls are a different matter they can be bleached then use sterilizing fluid to cure the problem. Is the mould black???
Peroxide might be a safer alternative to bleach. But bleach is surely the best. You could also try a bathroom mold/mildew remover such as Tilex, if you have that over there.
