Hey guys, I need to redo the clear silicone on this small basin.
I've put lots of HG Mould spray on but the mould is underneath so I'll need to remove it. I've got a couple of sealant guns, I think they're both standard size. Can I get a small tube of clear silicone to fit or does it need to be a certain size tube, and how long does a tube of silicone last? Because I know it'll never get used again for a long time and it would be a waste if it's a big tube.
The other thing is I have a few small black spots on white silicone at the back of the bath which won't scrub away, and again, mould spray not working. Any way to clear it without ripping the silicone off?
) I stripped all the old silicone out and cleaned everything down with bleach before using some of that no nonsense sanity silicone linked above. It's been fine ever since. Bleach seems to work fine.
that's half my problem. I have a garage loaded with tools and can't quite remember where half of them are so end up with duplicates.
