Hi,
I have removed my northbridge heatsink so i can put Artic Silver MX2 on it instead of the lame thermal paste the mobo manufacturer provides.
Now there is quite a lot of this "cement" left on both the chipset and the heat sink and efforts of using thermal compound remover has been ineffective.
any idea how to easily get this stuff off?
) but as a graduate Chemist (MSci
) its a pretty good bet...... i've used it to remove Akasa Paxmate before, and you are unlikely to find anything stronger commercialy avaliable.
And where can I get one?
