Removing options from right click
25 May 2004
Belfast
I have some things i would rather not have on my right click menu, such as the nvidia menu, as well as enqueue and add to winamp bookmarks, any idea on how to get rid of them?
Go to nvidia panel, open it up then click on "tools" untick context menu.
Do the same for winamp in the winamp settings. :p
Anything in that menu you can disable by opening up the program, and disabling the context menu option. Hope it helps!
Edit: a more explained way of doing it.... for nvidia anyway.
Right click on desktop>properties>settings>advanced>Your Nvidia card tab>tools> then untick the context menu option.
cyborg said:
I got the nvidia one ok, but winamp doesn't seem to have that option.
Actually, it does. ;)
Winamp Preferences (Ctrl + P) > Un/tick "Show Winamp in folder context menus in Windows Explorer"
Well that worked basmic, but the problem is i like play in winamp being there, just not the other two, they just get in the way. I need something so i can choose which ones are on it.
