21 Nov 2007 at 20:12 #1 svan svan Associate Joined 21 Jan 2003 Posts 496 Location Surrey I have downloaded a Job application, but can not change the margins and generally change the format of the document. Does anyone know a way i can unlock all Word 2003 or 2007 features so i can change this doc? Any help appreciated
21 Nov 2007 at 21:43 #2 MarcLister MarcLister Soldato Joined 7 Mar 2005 Posts 19,677 Location LU7 What file type is it? And why would unlocking Word help you? Do you mean that some options in Word are greyed out? Suggests that the file has been edited like this so that you can't edit the file.
21 Nov 2007 at 21:57 #3 IAmATeaf IAmATeaf Soldato Joined 3 Apr 2007 Posts 7,320 Location South of the Watford Gap! Sounds like the docs been protected, have a look off the Tools menu for Protection and see if that helps.
21 Nov 2007 at 22:19 #4 Raumarik Raumarik Soldato Joined 14 Jul 2003 Posts 14,927 Look for a padlock on the toolbar, if it's there click it to unlock. Muppets at work haven't realised that's all I've done to lock our templates
21 Nov 2007 at 22:19 #5 swinnie swinnie Soldato Joined 30 Apr 2007 Posts 3,095 Location Kent But if the file is protected he would need the password to un-protect the document
