Removing scorch marks from wooden desk..
3 Jan 2009
London
Recently, and rather stupidly I did some soldering on my desk and didn't put down enough protection and have left scorch/burn makrs on the wood.
Does anyone know how to get rid of them?
I did have a quick search on google but there were so many different techniques I had no idea which one to try - I don't want to make it worse either, I can live with the marks, its just annoying.
Heres a pic:
It's from Ikea and is beech.
those large ones will be at least a millimeter if not two millimeters deep - you'll need to take that off the whole surface or it'll look even worse.
frankly, not worth the effort.
If you have something like an orbital sander I'd definately give it a go. Even if it means going a bit deeper in the affected area you'll get a slight dip there but I'd rather have that than the more obvious burn marks.
Edit: Don't do it if it's only a wood veneer and not a solid top.
You could always get a big keyboard mat or something to cover it. That's what I'd do.
Yep I'm stuffed then :( ,cheers for your help
if you REALLY wanted/needed to do it, then you'd need a planer - a sander isn't fast or precise enough, and you'd just re-surface the whole desk, then sand it smooth and give it a nice oiling.
they're too deep that you couldn't sand 'em out without there being a large and/or deep dip in the desk :(
It's not laminate..
I did just get a little bit to see how deep they were and it just looks way to deep :(
Are you sure its not a veneer, most (if not all) of their desks that are beech are particle board with a veneer, not solid wood.
Which desk is it?
If it is a veneer its almost impossible to repair as the veneer is very thin and will not hold up to sanding well and therefore you are best covering it up (repair sticks from Homebase etc.) or buying a new one. Repair sticks are mostly used on scratches but I see no reason for them (bar looking awful) to be used on a patch. If in the unlikely case it is solid beech then sand the whole top down and reseal with a clear varnish.
