Hi all,
I need to remove the sealant around my bath and re-seal as the current sealant has come away.
So i'm planning on removing the existing sealant, cleaning with Isopropyl alcohol, letting it dry completely and reapplying the sealant around a full bath. Is there anything else I need to consider/do?
My main questions are:
1 - What is the best thing I can use to remove the sealant? I will remove most with a blade but will need some kind of chemical remover to do the rest.
2 - Which is the best sealant to use? I've been reading about Dow Corning 785+ but want to get some other views.
Thanks for your help.
