Removing single program from creative suite 6
10 Nov 2011
Kent
I am currently updating an image at work and was wondering, is it possible to remove fireworks from creative suite 6 without completely removing creative suite in the control panel?
Thanks for your reply,
Does this option come up when i select uninstall from add/remove programs?
I will let you know if it is tick to keep or tick to remove!
