Removing Skin Tags?
Status
Not open for further replies.
2 Feb 2011
Since starting my diet and going to the gym on a regular basis, I've noticed that I've developed some skin tags. I've got several on my right armpit and a couple more on my inner thigh. Now they are in places where there out of sight and they dont cause me any real hassle, but I dont like having them and want to get rid of them.
Is there a safe and hopefully painless way of removing them?
Go to the doctors, they freeze them, depending on the size you may need this done a couple of times, but they fall off after about a week and you are done.
Jcb33.
From the NHS website
Removing skin tags
If you have a skin tag that is upsetting you, consider making an appointment with a privately practising GP to have it removed.
Skin tags can easily be burnt or frozen off in a similar way to how warts are removed.
If your skin tag is small with a narrow base, the GP may suggest you try removing it yourself by:
tying off the base of the skin tag with dental floss or cotton to cut off its blood supply and make it drop off
cutting it off with fine sterile scissors
Do not attempt to remove large skin tags yourself because they will bleed heavily.
I guess you can use that stuff you buy from chemists to freeze warts off to seeing as that's basically what a GP does
I pulled one off my leg once, bleed for ages and then it came back, so i pulled it off again. It learnt its lesson
I remember years ago I did have a pretty large one on my chest. I tried pulling it off but it would never budge. I accidently pinched the base of it between my two fingernails, which nipped like hell for a second. The next day it had shrivelled and turned black. It broke off with the slightest touch and never came back.
Dont really want to go to the doctors about something so benign, so I might try removing them with a pair of nail clippers or sterile scissors. Most of them are pretty tiny ones anyway.
Status
