Hi all
I was wondering if anyone has any ideas on how to fix a problem I'm having with one of my kitchen drawers at the moment.
They are soft close drawers and one of them no longer goes all the way back and stays there, the mechanism pushes it back out a couple of cm.
I cannot seem to be able to remove the drawers from the sliders to see how to fix this. Looked at a few Youtube videos where you simply pull some levers on the underside of the drawer and then lift out etc but this just doesn't work.
Some pictures of the issue below in the hope someone knows this type of mechanism and can advise. The exposed screws in the first pic seem to be just related to removing the front fascia of the drawer as far as I can tell (which I've done).
Thank you
Thank you
