I'd say use a 'caramel wheel' but, it might melt the plastic under the paint if your not careful.
So I'm going to agree with the credit card and gently heat from a hairdryer.
It's a rubber wheel on a shaft normally used in a die grinder to remove stick on stripes etc from car paint. It's nearly always called a 'caramel wheel' because its caramel colour and smells like caramel when you use it.
