22 Apr 2008 at 22:31 #21 fat-600 fat-600 Associate Joined 30 Nov 2007 Posts 387 Location west london double post
22 Apr 2008 at 22:32 #22 233 233 Soldato Joined 21 Nov 2004 Posts 13,574 Location Wishaw mondeo tbh or call chuck norris
22 Apr 2008 at 22:35 #23 TaKeN TaKeN Soldato Joined 18 Aug 2005 Posts 13,189 Location Shropshire Paradigm's idea of the araldite sounds good !
22 Apr 2008 at 22:41 #24 WHAT!!! WHAT!!! Associate Joined 5 Aug 2004 Posts 1,783 Location S Wales Spray it with WD40 inside around the stuck battery and hopefully it will help loosen whats got it stuck and just ja ja ja ja ja jiggle it abit
22 Apr 2008 at 22:51 #25 Nitro_Junkie Nitro_Junkie Associate OP Joined 18 May 2004 Posts 1,781 Location West Sussex the boiling water sounds like a winner, maglite's are water tight so could work failing that I'll try the WD40
22 Apr 2008 at 22:56 #26 ryder ryder Associate Joined 8 Dec 2003 Posts 1,008 Location Bournemouth [UK] Nitro_Junkie said: I've tried giving it a good beating but to no avail. Click to expand... That's the problem, give it a bad beating. The battery cant be that stuck, and it's not like you need to be careful, it's a maglite! Be a man!
22 Apr 2008 at 23:09 #27 Liverpool-Lad Liverpool-Lad Associate Joined 18 Oct 2002 Posts 1,519 Location Liverpool - UK. Tie the torch to a sturdy piece of string at the bulb end. Swing violenty and the centrifugal force will push the batteries out.
22 Apr 2008 at 23:09 #28 Lashout_UK Lashout_UK Soldato Joined 2 Mar 2004 Posts 11,919 Location SE England shaped charges
22 Apr 2008 at 23:25 #29 lbratch lbratch Associate Joined 13 Jul 2006 Posts 117 Location Jersey No More Nails on the end of a stick?
22 Apr 2008 at 23:32 #30 2StepSteve 2StepSteve Soldato Joined 24 Apr 2006 Posts 6,439 Location SE England buy a can of IPA and blast that inside it will work much better than WD40 leaving no residue or gunk. Will be 100% non harmful for the torch aswell
22 Apr 2008 at 23:48 #31 bushmins bushmins Soldato Joined 30 Aug 2006 Posts 4,774 Call 999. Or the ghost busters.
22 Apr 2008 at 23:51 #32 Begbie Begbie Caporegime Joined 20 Oct 2004 Posts 27,011 Location .... Marmite! Tried a screwdriver to wedge it? Tried anything?
23 Apr 2008 at 05:32 #33 Amnesia Amnesia Soldato Joined 22 Jun 2007 Posts 9,621 Location Buckingham Palace C4
23 Apr 2008 at 09:22 #34 BenhB BenhB Associate Joined 3 Jan 2008 Posts 317 Location Dahn sarf! Stick a screw driver / spike through the bottom of one. (Wear rubber gloves too).
