Removing thermal paste
Do a quick search on the net m8 but i do beleive you can use some wipes you can get from chemists or local pc supliers in your area maybe.Also cotton buds you can use also with solution on think the solution is polypropelene cant spell it lol but wait until some one with more experience can post an answer.
If glup - Isopropyl alcohol (IPA) or rubbing alcohol is almost as good.
Try not to use fiberous materials - kitchen roll is better then a cotton bud. lense cloth or coffee filter paper even better (for final wipe/polish after using kitchen roll to move the gunk)
If it's hard residue IPA or TIM cleaner is best.
razor blade and some care comes a close second
I knew it was some sort of chemical lol wrong one i said though.I was going on what i saw on youtube videos for removal of the paste.
kitchen roll and alcohol, like nail polish remover.
Always remember to give the surface a good polish before you apply the next set!
I've always used Isopropyl alcohol, although my brother did buy some of that Arcticlean stuff which seems to do a pretty good job too :)
nail polish remover and them cotton pads ladies use to remove make up.
cotton ear buds.
