Removing water cooling and puting it back again?
12 Jun 2007
Ireland
Well i got a new mob p5k deluxe. i have to remove my water cooling to put the new mob in any tips how to remove water safely ? as this will be my first time.
and should i reuse coolant that was in tubing or use a new one ?
Thank you for advice ;)
u see i have to reloop it as now its cooling cpu / gpu / and part of mother board i will remove the part that cools the motherboard and make my loop smaller as i don't need it
As long as its still ok you can re use it, however if it were me I would get some new, and clean out all the blocks too
