Rename software | Excel function? | please help!
30 Aug 2003
Straya
Hi all
In quite a bit of a pinch at the moment and need something done for work urgently, that is holding up launch of a clients site!
I have a bunch of images (see below for example) that I need renaming.
Code:
18.05.2007.101680122.zip
I need everything excluding the file extention, that falls after the first fullstop i.e.
Can anyone do this for me (if I list all the files here) or could tell me how to do it?
MANY thanks!
I think you could get a plugin for excel that will allow for regex find and replace... so you could use that if you find a plugin.
Not an excel guru or anything.
