Rename Tool
10 Mar 2003
Hi
I'm sorting out my photos and such like and a lot of them are labelled as follows:
IMG_0091.mp4
I'd like a utility that can rename them to be a little more informative but it has to have some intelligence in there to know that if the above got renamed to say: Family_Party_0001 then the MP4 would have to also be a 0001 just so I know it references the same thing. Is there any tool out there that can do it ?
Thanks,
M.
Not sure if you want something more complex but..Select all the files > Right click > Rename > type a name > all files will be renamed to <Name> (001).jpg, Name (002).jpg, Name (003).jpg and so on.
So you could select all the files that are to do with Family_Party, right click them, rename them, and all the files will use the same name but with files using the same extension using (001), (002). Where it falls down a bit is if files use different extensions as then you can get Family_Party.mp4, Family_Party (001).jpg, Family_Party (002).jpg, Family_Party.png, etc, etc.
