Renault equivalent of VAG-COM/VCDS
21 Oct 2009
As above really.
I believe its called CAN CLIP but I need confirmation/need telling the correct one.
Also, best place to buy it?
And can it do a injector ECU reset (to tell the ECU that a new injector has been used to recalibrate and so on)
Asking on behalf of a friend.
Thanks in advance for all replies
Ash
Clip is the stuff for Renaults. I don't think anyone 'buys' it, they download 'copies' online. And yes, Clip is what you would use to recode a new injector.
I see. Thanks for that :)
With regards to the adapter then, what would you recommend? I assume I can't use the VAG-COM one I own for example.
