Render Farm
24 Aug 2009
I'm looking for a small, cool, power efficient way to get as much CPU smash for the money for a render farm I want to do so I can more effectively render my 3d all they will need to do is run the render utility so hard disk,GPU,Optical Drive etc space is not a requirement.
It all depends on how many cores / render buckets you want and how
much your budget is. Price/performance wise, it's hard to beat phenom x6
based systems at the moment or wait till bulldozer comes out.
What are tools are you rendering with?
Is noise a consideration?
How much money are you looking to spend?
well atm I have 3700 for this farm atm...noise isn't a large consideration as long as its not equivalent to a jet taking off.
Its probably more efficient to buy/rent Ghz on a render farm rather that set one up yourself..
I just put my last render in and that would cost me an 8th of my Farm >_>
hmmmmmm.......now all I need to do is find loads of cheap Quads does he say how much this project cost him?
A starting thought? all I would need to do is case them? But now I really need to look at rendering software >_> does anyone know a package that works on linux that can take 3ds MAX?
3ds max doesn't run on linux but maya/mental ray do.
btw, four 1090t systems instead of six 640s would be
around two hundred quid cheaper and would take up
less volume. I run 20 core render farm (mixture of hex
and quads I've been collecting over the years) for
rhino/max/vray under xp x64 and really pleased with
the speed.
I tried to do this when my missus and house mate where rendering out their dissertation projects (with the idea of helping loads of 2D/3D people who were all struggling to get decent render times off their mac books).
The biggest problem was throughput, you need a fast network and very fast central storage! Was a fun little project but was of zero use to my GF!
This was before the days of cloud computing!
I could add a gigabit switch for them and go from there what do you mean by very fast central storage?
I found a 3ds Max render manager for linux
I would try to obtain some benchmarks on what type of cpu requirements are best, also if things like L3 cache are required.. such things will probably decide for you.
also I assume the rendering is CPU based and can't use GPU based encoding etc?
Correct me if I'm wrong but I believe drqueue only manages render queue of jobs
composing of a number of tasks which spread over different computing nodes.
I think you will still need a cluster of windows based 3ds max clients.
Some of the software can but its all a bit iffy I would rather I had 1 that can do everything.
ahh right, you may want to look at an i7 based system rather than amd. should check MM to see if you can source 2nd hand cpu's.
This isn't to make an awesomely powerful setup more how much can I get in terms of CPU power for the smallest amount payed.
I understand that, but there is no point in buying 4 cheap x3 AMD chips that actually may actually provide less speed (as far as encoding is concerned) than a single chip. not to mention 3 more sets of ram/psu/mobo etc etc.
just my two cents.. as mentioned previously I would check benchmarks not only price tags
