Renewed £500 spec please chaps
8 Jul 2013
Chaps, in November you kindly spec'd me the following package (I have a monitor, Keyboard, mouse, OS and 1 (maybe 2) 320Gb HDD. So if there is room for an SSD, please consider.
I've been holding on until the sales and just about to buy. Has anything changed since that will get me something better for the price?
Previous spec
YOUR BASKET
1 x HIS Radeon R9 270X IceQ BOOST 2048MB GDDR5 PCI-Express Graphics Card with BattleField 4 PC Game Included (H270XQ2G2M) £155.99
1 x AMD Piledriver FX-6 Six Core 6300 Black Edition 3.50GHz (Socket AM3+) Processor - Retail £89.99
1 x Patriot Intel Extreme Masters 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PVI38G160C9K) £53.99
1 x BeQuiet Pure Power L8 500W '80 Plus Bronze' Power Supply - With 120mm Silent Wing Fan Built in £53.99
1 x Gigabyte 970A-DS3P AMD 970A (Socket AM3+) DDR3 Motherboard £53.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £45.95
1 x Xigmatek Asgard 381 Midi Tower Case - Black / White £36.95
1 x Pioneer 24x Internal DVR-221LBK DVD Rewriter - OEM £17.99
Total : £523.82 (includes shipping : £12.50).
The CPU is probably mostly useable, the GPU definitely, basically everything else as well. You might want to do an upgrade of the CPU though, would make a good difference. Maybe an i5 4670k or i7 4770k with the G1 Sniper Z87 Motherboard would be a good bet. Probably want a higher power PSU as lee said, the i5/i7 might take more power and maybe get a 600W for higher headroom should you want to upgrade more :)
The spec in the ops post hasn't been bought yet from my understanding.
Aaah okay I understand, sorry. I think you can get some slightly quicker RAM for that price, though don't quote me on that and it doesn't make all that much difference anyway. Lee's PSU he found would be a better alternative, and you can save a couple of quid on getting the OcUK DVD RW (made by Samsung I heard?)
Yeah, don't buy those though, at that time I didn't realise you didn't already have that spec - it'll put you like £200 over budget.
