Renewed watercooling list
30 Dec 2011
Essex
I have planned a few months back a custom watercooling loop. I have now renewed it due to case change. If anyone feels I could make any significant changes please be free to tell me what they might be.
XSPC EX240 120mm Radiator - Black AND XSPC EX120 120mm Radiator – Black
Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin x5
Mayhems X1 UV Green Premixed Watercooling Fluid 1L x3
Masterkleer Hose Pack PVC 15,9/11mm (7/16ID) Clear 3.3m
EK FC580 GTX+ Full Cover Waterblock - Nickel Plexi **EN Nickel Plating**
EK Supreme HF CPU Waterblock - Nickel Plexi
OcUK Value PSU Bridging Connector (24 Pin)
OcUK Tech Lab - D5 Vario Pump & Alphacool Clear HF D5 Top Value Combo
OcUK 1/2" G1/4 - High Flow Style - Black Nickel - Compression Fitting x12
Phobya 5,25" Dual Bay Reservoir Black
OcUK Tube Cutter Aluminum 3-14mm
Thanks for helping :cool:
might want to change those fittings, as those are compressions designed for 1/2" tubing which is bigger than 7/16" and will only work with 1/2" tubing unlike barbs that are for 1/2" tubing
I would generally say Bitspower are all overpriced, you can get the same quality much cheaper but it depends if you want them for the name or not :)
But the ones you listed above are the correct size yes :)
