Wife just mentiond today the drawers in bedroom do not slide back smoothly so my job for today was finding out why - Pulled drawers out and it was the screws holding runners on drawer unit itself that had come loose. Tightened them up and were fine -Been in now 15yrs.
So from this job I started to check wardrobe door screws and everyone was loose -A lot of this because the thread had gone in door which is 18mm MDF.
So my next job is drill out the hole and put a plug in but before I do anything I checked online and found some Blum hinge plastic dowel that expands when you screw a screw in.
So has anyone first hand knowledge of replacing screws and fitting any sort of plug to do this job - Total of 32 holes. Also tightened up doors in spare room but not so many loose screws.
I have also checked the kitchen and bathroom screws but they were ok.
