hi all
i have fitted some new Renthal Ultra low bars to the Hornet
have left them to full size (not cut them), i am using a pair of Tuano Mirrors.
if i have the levers on either side up against the switch gears the mirrors hang out a lot, what is the norm for over hanging mirrors? should they be in line with the bar ends? Ie not to stick out further then the bar ends?
pic of them fitted
I have moved the levers way from the switch gears a little, which have pulled the mirrors in a little
just after some opinions, do I need new narrower mirrors? or is it a matter of performance choice?
Thanks
pic of them fitted
Thanks
