Renting Servers
It all depends what you rent. IF its just a server then you can only modify game parameters like round time, map rotation etc. This are cheap and only cost around £5 a slot, depending on game.
You can also rent a dedicated box that willl alow you to run various games but is much more expensive. Look at multiplay or rackage i ve used them before and aren't to bad.
I rent a dedicated server from Multiplay.
They might not be the cheapest, but their management system is a doddle and I have rented one for years off them now.
I use Gameservers.com for l4d1+2 ocuk3 + l4d2 ocuk4 and a dedi server for other computer game servers.
I did use INX and although their technical support is very good, their servers randomly failed too often for me to stick with them.
What kind of server do you want? What game? How many slots? Tickrate? Location?
Looking for a private 8 slot server for AvP3 (When it is out.) I have been in contact with a few of the sites mentioned and they say that they will have it.
I don't know what tickrate is.
What difference does location make?
£5 per slot is very expensive :|
An 8 slot private server will cost around the same as the advertised prices for L4D / L4d2 servers.
You should be looking at no more than £8 per month. :)
