The headphones themselves are fine, but the plastic slider parts have disintegrated and one of the ear pads has started to break. The covering has partially separated from the foam. I've made a temporary fix with gaffer tape (the universal repair material
) that stops the earpieces falling off, but it's less than ideal.
Option 1 is to buy the slider repair kit and replacement ear pads. About £50.
Option 2 is to buy some new headphones.
I like the DT770 Pro, but it does have one problem for me. My head is big (literally - I've measured it) and I wear glasses and the DT770 Pro has a high clamping force. That's why the slider parts have broken (and it's less than ideal for comfort). But a quick look implies that the DT770 is still very highly rated as closed back headphones and I didn't see anything significantly better at anything like the same price point.
EDIT: I have the 80 Ohm version as I'm not using an external amp.
