Repairing a scratch
27 Mar 2009
Middlesbrough
Hoping someone could give me some advice...
My car has this scratch on it and I'd like to put it right or get it put right, can anyone shed any light as to whether this looks like something which I could do myself (I don't have a huge amount of faith in my skills to be honest) or is it a better idea to take it to a body shop to be done? If the latter any idea of what kind of price it'd be and any suggestions for places in the North East would be appreciated!
That looks pretty bad tbh. I'd be very surprised if you could repair that to a finish where it's not noticeable.
How did it happen?
How did it happen?
Not sure how it happened as it was like that when I got the car (haven't had it long).
It looks worse in the pictures but still something that definitely needs sorting out.
Seems like a body shop might be the best bet then!
Also just noticed that the pictures appear to be upside down, not quite sure how I managed that :o
Does it catch your nail? If so it's a respray job. If not try G3 Pro scratch remover.
Just been out and had a paw at it, it does catch on my nail so looks like it'll be a respray.
I'll have to have a hunt around for somewhere local, any idea what kind of cost I could be looking at?
You could fill the scratch with touch up paint so it proud of the surrounding paint, then wet sand to level and polish the area. It wont be to the standard of a bodyshop repair but a vast improvement.
Depends where you go. I just had 2 sills and a spoiler resprayed for £220 from a recommended reputable local place. I asked them about a small bit of lacquer peeling by the rear wheel and he said to do it properly he'd have to respray the whole rear panel up to the top of the door which would add £100 to the job.
As above, a spray will be best. If you just want a decent fill though, Dr Colour Chip is easy:
http://www.drcolourchip.co.uk/
Used recently on a pearlescent black car, admittedly much smaller scratches and a few stonechips, but happy with the results.
If it catches your nail then it's defiantly a Re spray. What car is it? If that's the front quarter panel you may be able to source a replacement cheaper
Yea I'm thinking a respray will be the way to go, not too mention I wouldn't want to try myself and mess it up even worse. It's getting looked at tonight so hopefully it won't be too bad a price!
The car is a Fabia Mk1, it's actually the rear above the petrol cap, the pictures are upside down for some reason which makes it harder to tell.
Not sure about colour difference but have you tried to find another panel from another car? Fabia Mk1s are pretty common there's got to be something.
I haven't looked down that route, not sure if that would work out a better (cheaper!) option :confused:
I'm waiting for some quotes to come in to see what it's likely to be, had a chap pop round last night who deals with more superficial stuff and said it wasn't suitable for the system he uses as it'll likely the full panel will need doing and it goes above both doors to the windscreen.
He said it looked to him that it'd possibly been repaired/resprayed previously and that the filler had shrank or something causing it to crack as it doesn't look like something has scratched it... There are also a few small slightly raised sort of crinkles above that could be more of the same :(
I was thinking the same
Just get a can of spray paint from halfords (colour matched obviously), spray a small artists paint brush and carefully paint over the scratch. Then when dry, wet sand and polish
