My NEC Versa P700 has developed an intermittant fault, now i know a lot of people will think that its nearly 3yrs old, so not worth repairing but its still a decent enough spec (P4-M 2.2, 1gb ram, and a screen thats native res is 2048x1536!!)
The fault appears on startup, you turn it on and it just sits there, does nothing...if you belt it one then turn it off/on again it works. It can take several thumps to make it work but otherwise its ok!
Does anyone know of a guide to dismantling a laptop (particually versa P700!) as i have attempted to find what i assume is a loose connection but never get far when taking it apart.
Pls help!
Pls help!
but only one from experience of taking apart about 5 different models of varying brands.
