Hello,
Bought a 2nd hand Coolermaster PSU, a Coolermaster rs-430-pcap for some pocket cash.
This PSU worked fine before, I believe the seller, he looks like a reputable guy who sells a lot of stuff and he offered me to refund the money without having to give back the PSU. He says it's always worked fine in a pc, and been gathering dust for 2 months after removing it.
So, I plug it in, nothing, just 5VSB/indication led, but it won't turn on.
So follow up with the classic paperclip method ( short green wire with black wire, make sure to have some kind of load on the PSU though, so I had a dvd player and a 120mm fan hooked on it). It started.
Plug back in a Mobo > it fails to start with both the power button, and paperclip method. The moment I pull the 24 pin plug ( note that I already removed AC power), it starts up again (with residual power in caps, as paperclip is still in place connecting green and black).
What could this be, some kind of short protection ?
I checked over the caps in the PSU and can't see any abnormalities ( leaks or swells, etc...).
Any ideas what part could be the culprit ? Does anyone know of a good guide for fixing psu's/electrical components. Or does anyone see any abnormalities here:
? It's a low power Pc PSU, not a Microwave or CRT tv.
