Repairing PS2 connector on mechanical keyboard
12 Dec 2005
I have a Q-PAD MK50 keyboard and it's a PS2 connector
The pins inside the PS2 connector have bent and one has snapped off so the keyboard is now unusable
Is it possible to replace the PS2 connector on a keyboard
I imagine it might not be worth it
You might be able to replace the lead and the connector with one off another keyboard. I'd start by opening it up to see if the lead is soldered onto the board or if there's some sort of connector you can swap onto another lead.
EDIT: I might even be worth pinging their support a email to see if they can sell you a replacement.
I've just opened the keyboard up and the cable is just connected on to a block which you can easily take off so it would just be a matter of them supplying me with a new cable but I don't think they will
QPAD don't really have the best support
Chop one off a working keyboard with a foot of slack.., chop the end off yours, solder the wires together and cover with heatshrink.
Will work fine. It's 6 wires.
