Deleted User 298457
Deleted User 298457
Hi folks,
I've put this off whilst I was doing my main rooms/kitchen/utility. Its started to get a bit annoying to look at though, and the shoe cupboard I've built in MDF is bound to get dinged by the humidity of the garage if I leave it in there any longer.
To complete the hall I need to first get a handle on this front door arch. In general, I plan to strip all the paper, sand and paint, so ideally limited/no wallpaper. I guess I could plaster, but given it is a slam shut door, I fear it won't last particularly long. I can also trim some wood and gloss it, but this doesn't seem to be in vogue anymore - I suppose you'd then architrave over the top. Or I could PVC frame it? Which also seems a bit gash.
Any thoughts? I did scavenge some 12.5mm plasterboard from the tip in decent lengths....
