Hi all, I recently ordered the Titan Fusion system here, and over the past two weeks it's been turning itself off with no prior warning or precedent.
It has turned itself off mostly when playing games, however I have had instances where it's turned itself off just browsing the internet. There was even a case where it turned off, and I immediately rebooted, went into the BIOS to check system temperature, whereby it turned itself off again!
I've got XP Pro 32-Bit installed as my operating system, and just FYI the CPU and System runs at ~46C and 33C respectively when idle. Another thing to note is that I have to take out the power lead and put it back in after a random shutdown in order to start the machine up again.
I will contact OCers directly, but I thought I'd make this thread anyway to see if any of you could give me an inkling of what's going on here, or what the most likely outcome will be. I suspect it's a PSU problem, since the system temperature seems normal- but it does seem to be related to system temperature since I have to leave it to "cool down" to reboot without crashing quickly again.
