- 18 May 2010
I know right, weird. But hear me out -
I have a reference 290X that I am thinking of getting an AIO for with a GPU adapter as I am growing tired of the noise, it was only meant to be a temp card but my priorities have changed and its looking like the 390X may (Or may not) be out of my price range based on rumors.
Long story short I'm sticking with 1080p and a 290X for at least another year.
With all the reading I have done about changing the cooler it seems there isnt much out there that will reliably keep the VRM heat under control without sticking heat sinks to them which I just don't fancy doing, add the cost of an AIO and adapter and at minimum I'm looking at £55 for the adapter plus refurbished H55 cooler
If I sold my reference card for £150 and bought an Asus 290X Direct CUII for £230 thats an £80 difference with a brand new card, this option also has its issues though, Asus seem to have a pretty bad rep when it comes to warranty issues and I have no idea what the Direct CUII cooler is like IE how noisy it is plus it puts the heat in the case which I am not a fan of.
So what do you think, stick with my current card and go AIO or get an Asus card to replace it whilst they are cheap?
Thanks
Thanks
