replace a 670gtx
23 Sep 2008
can you reconmend a card to replace my 670 gtx which i think is broken want one about same or a better but cheap ty.
Hello, It's worth using some sites to compare it's performance up to newer gen cards, Without more info there's not a lot anyone can suggest other than common sense equivalents such as a 670 is close to 760 performance but it was replaced by the 770 which edges a 680 out of the top spot.
How much is your budget?
Are you happy with slightly less performance if it's cheap or do you want more?
Are you interested in b grade cards (If so check out the clearance section)?
Secondhand (If so look around and see what's on offer in budget)?
Must it be Nvidia?
670 v 760
http://www.anandtech.com/bench/product/1349?vs=1038
960 v 680
http://www.anandtech.com/bench/product/1596?vs=1494
R9 285 v 680
http://www.anandtech.com/bench/product/1512?vs=1494
R9 280x v 670
http://www.anandtech.com/bench/product/1041?vs=1349
Play around with the Anandtech bench for comparisons and remember to use the GPU 2015 and GPU 2014 sections.
More importantly don't depend on one review site,
Find a couple more review sites and compare all the results,
From those work out an average performance level for what ever cards you are considering.
