- 25 May 2008
- North Wales
Would you replace them in pairs or just 1 at a time when an issue arises ?
I've got a seized rear caliper on the Swift, ordered a replacement but ended up getting the other side first due to a listing error so i've actually got both sides now. It'd be worth about £100 refund if i send it back so i'm thinking of doing that and just replacing the borked one.
Generally i do like to replace things in pairs, brake pads and discs obviously and suspension stuff.
(this is pending changing the faulty one and then not snapping the bleed nipples off the other ones and needing to replace them anyway...)
