So, I'm now running an i7 4790k, and 980 SLI, from my previous i7 920 and 7970/7990 trifire, which was watercooled.
I am using the same case - a Lian Li PC-P80. It's an older case but is relatively large.
I have an old Thermochill pa120.3 rad. In fact, I think I have a 2nd one somewhere, along with a load of Gentle Typhoon fans (don't seem to be able to get these anymore).
I also have a Laing D5 and a DDC with an XSPC Restop ( http://www.sidewindercomputers.com/xsacreforlad.html ) and a Swiftech Apogee XT cpu block.
I'm currently cooling the 4790k with a H80i, and the 980s are stock.
I want to go proper watercooling again, and I remember from my initial build plans I can get a pa120.3 in the front of this case in addition to the one I used to run vented out the base (case is on wheels lifting it from the ground).
Thing is, I'm not sure if it's worth just scrapping my old kit and replacing it all?
Are the Thermochills still rated as decent radiators? Are modern pumps/tops much of an improvement? Is the waterblock worth reusing?
I kind of feel a Carbide 540 would be smaller and prettier. Probably allow for neater wiring as well.
However, replacing everything also feels like a bit of a waste. For the cost of some new tubing and two GPU blocks I have everything to make a complete loop....
Thoughts?
Thoughts?
