After a general check at the weekend I identified on my E46 330d the rear pads are getting low, and look to have just over 2mm friction material left on them (no lights on the dash yet). I'm going to get the pads replaced next week and as I was ordering the parts I thought I should probably replace the discs at the same time.
This evening I took the wheels off and measured the discs with a micrometer and they came out about 21.2mm minimum. There is hardly any lip on disc, the surface is even and not scored so by all accounts they look in pretty good condition. The minimum stamped on the disc is 20.4mm.
I don't want to be cheap and scrimp on brake parts, but I am wondering how worn the discs are in the grand scheme. I can't seem to find for definite what thickness new discs are, but some sites suggest 23mm. Doing some research online, most people recommend that the discs are changed around every second pad replacement as long as the discs do not have an excessive lip or scoring.
Any ideas on the above? In an ideal world I would just replace everything, but it makes an inexpensive quick job into a much longer job, so I would rather replace the discs when they need to be done.
Cheers,
Ian
Cheers,
Ian
